Zdravim, mam problem s tim, ze po nastartovani spadnou otacky a motor se klepe s otackami tak cca 400. Po zahrati vse v pohode. A dela to jenom obcas. Auto ma najeto jenom 30 000 km. Vycistil jsem skrtici klapku, dal novy filtr, ale zadna zmena ( ani nebyla moc spinava ). Mam podezreni na bud MAF ( vaha vzduchu ) nebo O2 senzor ale diagnostika nic nehlasi.
A pak jsem nasel nahodou nasledujici informaci na netu ktera sedi na to co se mi deje:
Field Remedy: 2423 Subject: Engine Z12XEP - Rough idle and bad throttle response after cold start Models: Engines: Option: Corsa-D 2007...2008 Z12XEP Complaint: Customer complaint rough idle and bad throttle response after cold start. Cause: With usage of heavy-volatile fuel a mixture leaning could appear. Production: Improved engine software has been introduced in production as of engineno.: 19RP5708 (January 2009).
Z cehoz vyplyva , ze podle paliva se muze stat, ze je smes chuda a resi to prehrani software v ECU.
Myslite ze bych s tim mel tedy do autorizaku nebo preventivne vymenit MAF nebo O2 senzor nebo neco jineho ??
